vcStringProperty
Typed property that holds a value.
Parent: vcProperty
DefaultValueString OR NoneRWGets or sets a default value for this property. Value None means that an explicit default value is not defined.
TypevcPropertyTypeRGets the property type.
ValueStringRWGets or sets the property value.
waitForobjectString OR None value,
waitForNotobjectString OR None value,
